02 650 prairie over heating
5.4K views 8 replies 3 participants last post by  cojack
#1 ·
New to the forum and to the kawi, but here it goes i got the kawi in on a trade rode it for a day and well it was really dirty when i got it, so i pressure washed it all down and let it sit for 2 days while i was working then i got on it Sunday and rode maybe 20 minutes and the temp light was flashing so i stopped and the fan ran for about 3 minutes after i shut it down, then rode back to house and did the same thing. I think i may have pressure washed the mud in the raidiator ( is this possible) or is the thermostat stuck... yes it is full on fluid.:)
#2 ·
yes u pushed the mud in the rad u have to clean it now it is common for people to do this on bikes it happens alot here
#4 ·
some will tell u u can some will say u cant its really up to the owner just think tho the thermostat is in there to keep the motor at the minimum operating temperature of the motor thats all it does i would keep it in i have never had a problem with them before but i u want u can remove it
#6 ·
Pull the inner fender plastic off so you can get at the rad, and give it a good cleaning. Don't bend the fins with the pressure washer.
#7 ·
02 prairie still overheating
Ok to the front rack and plastic off and cleaned the raidator out (is was real muddy) Put it all back together and drove it around (pretty hard) for 30 minutes and the temp light starting flashing once again. Any ideas, thermostat? don't believe it has a air lock as to the best of my knowledge the system has noot been apart.
If i take the thermostat out and run it for awhile and it does not overheat then i need a new one right? (just a thought)
#8 ·
Did the fan start to run well before the temp light came on? If not, then the sensor may be bad.
