awesome info.....thanks!!!!! I do have flywheel pullers and bearing pullers from other work I have done. Machine has 3300 miles on it and the owner kept it in a heated garage and didn't mistreat the machine at all since new.......he is an older fella that used it for wood hauling & deer hunting....so I am confident in it not being "beat" as he has stated to me at purchase. I am under the impression from your comments, that as long as I would be tearing the engine down.....the cylinders should be honed or bored out, new rings installed, valves cleaned & polished & re-seated perhaps, etc.
Sounds more like a motor rebuild than just fixing the noise issue......am I thinking right here???
Also, do chains need to be replaced?? any lifter adjustments?? Do they make a rebuild kit per say with gaskets, rings, bearings, chains, etc??
If I am going to a cost evaluation, guess I better know what to be buying if I do this myself full bore with my son.
thanks!
Jp
