Fuel pump not priming everytime?
14K views 28 replies 10 participants last post by  chucked
#1 ·
I was wondering what might be my issue on my wheeler? Most times it will prime and fire but it seems to be a little more frequent. I can hear the relay kick on under the seat but i dont hear the fuel pump. After a few tries of starting it or cycling the key it will kick on and be fine.
I was wondering where i should start checking?
#3 ·
still having this issue.
sometimes it will die driving it or spudder then stall.
i did the filter mod on the fuel pump of taking out the second screen inside the canister.
#4 ·
sounds like u need to do a search on fuel pump issues or fuel pump install.
#6 ·
I have waterproof fuses on the way and will put them in next weekend. I'm wondering if they are corroded under the fuse box. It's not a constant issue, I can go for days without a problem then it re appears.
#8 ·
Fuel pump is going out worked on one while back and would run good then would pop miss and die then won't start next day it would run for a while,it was the fuel pump
#9 ·
Sounds more like the pump. When a wire or connection starts to corrode and fail, it usually gets a lot worse really fast, until it won't run at all.
#10 ·
Well if It's the pump that's OK. I see you can buy them for under $50.00 now.
#11 ·
UPS man just delivered these. Looks like some Good fuse holders.
#14 ·
all I did was loosened the bolt and flipped the fuse holder over.
#16 ·
well, yes and no.
now the pump primes every time but it will only idle now, if i try and give it gas it stalls?
a couple of times i got it WOT but its stil sputtering and stalling..:(
would this be the fuel pump perhaps?
#18 ·
I think the rest of the harness is fine but I can't say for sure. I did go ride again just now and it ran great? Wheelies on demand, no stalling or hesitation?
#20 ·
gremlins are right! i just dont understand it? i could see the fuel pump going out and maybe overheating issues causing the strange on and off problems i am getting. but when i replaced the fuse holder the problem happened minutes after riding. later that day i rode it for a longer time period and had zero issues?
#21 ·
Rode it around the yard a few times since, no issues?? Runs normal.
Wish I knew how to diagnose this.:confused:
#22 · (Edited)
Tried to use the quad again...gremlins are back!
Same thing, idle's but if you give it some throttle it misses and back fires. I did take the second filter screen out of the fuel pump housing a while again because it got clogged. So that issue is already taken care of.
#23 ·
Prolly a dumb question cause you sound like you have your stuff together, but did you put a secondary filter in down stream of your pump?
#25 ·
Sorry for the late response. I never got an update about the thread.
I will check into the fuel pressure and see if that tells me anything.
Anyone have Amy pics or anything how they did a pressure check?
Or Maybe I'll just do the flow test.
#26 ·
With the flow test you take the line off at the top of the fuel pump, take a length of 1/4" hose, attach one end to the fuel pump and the other end into a bottle. I think its supposed to move 3 oz of fuel every time it primes when you turn the key on. So what I did is take a 20oz bottle and do the test 6 times, which should be 18 oz, or close to the top of the bottle. When I had issues it wasn't nearly that much. Do a search for my thread titled "corvette fuel pump". I will double check my numbers at lunch when I can check my service manual.
